Tree-Farmer
When your gas gauge doesn't work and you want to measure how much gas you have in your tank, What's your workaround?
What do you use to stick in your tank to see how much gas is there?
Years ago, my dad had a metal rod that was brown, with a wire on it, so you wouldn't drop it into the tank. That metal rod
worked well. You need something that's a darker color, so you can easily see the gas line/level.
I need to find something for temporary use. Next, I need to fix the guage or the sending unit.
