I -we need you to answer my question about where you
connected the hoses you ran to the splitter. I am not
100 percent familiar with that system but I do not think
any of the ports on the cast block that the rock shaft is
in are set up to take hydraulic flow from to operate
remotes. You do however have an add on auxiliary
bypass plate that operates the loader lift. See the
linked post. That is bolted between the lines and the
touch control. I believe I can tell you how to connect it
but the valve for the splitter will have to stay on the
tractor. That is because the fluid has to loop through
the valve, the loop cannot be disconnected with a
quick coupler that would block flow and dead head the
pump. I need a photo that shows the entire connection
setup for that loader valve. Essentially the fluid will
need to come out of that fitting on the block the line
connects to you have a tee in. This will be a straight
connection no tee. It will loop through the valve you
are adding for the splitter and then through the loader
valve. Then out of the loader valve into the port in the
bypass plate as it does now. The fluid flows back in
there to operate the rock shaft. Also need a picture of
the valve you are adding for the splitter. I can tell you a
fairly simple way to get a couple test run strokes or
part strokes to see if you are satisfied with the
pressure and speed it operates with before you go
through all the connections. Get the machine in a place
you do not mind a little oil is spilled. Set the loader on
the ground. Disconnect the hose from the loader valve
that goes to the cylinders I think it is the one shown
with the galvanized elbow pointing down. Connect a
hose to that that goes to the push or extend port of
the splitter cylinder. Now when you operate the loader
lever to the position that would normally raise the
loader the splitter cylinder will extend at the speed and
pressure that it will once you get all the valve set up
properly. You will also need to have the hose for return
side of the cylinder open an directed into a clean
bucket. But two things are going to happen. If it is a 4
inch cylinder in part of the stroke it will empty the
small reservoir. This will be less of an issue when
correctly connected because the return oil from the
cylinder will be flowing back in the system. Second,
the cylinder will have to be returned by physical force
probably using a chain and a pry bar. To return it the
loader valve will need to be held in the down position.
This is because that loader is from what I can see that
loader is set up with one-way cylinders.
Post with info
