PapaBear24
New User
If I understand the codes correctly I have a 1969 Ford 3000 industrial tractor with a 540 PTO and a 6/4 manual reversing transmission.
C5022K
9G03B
C255234
C5NN7006AR Transmission
Here is my conundrum: During an engine rebuild, I needed to change the clutch throw out bearing. In researching the transmission diagrams, this model tractor did not have a 12 inch clutch assembly, an internal return spring, a self greasing assembly and a very large throw out bearing, which is apparently obsolete. The transmission resembles either a 3500, 4000 or 5000 tractor transmission. The throw out bearing is O.D. 4 5/16; I.D. 2 1/4 and 1 5/16 wide and the hub is 4inches long. There has to be a viable solution but, most of my solutions come up a pallet of bricks to short. Would it be possible to change the size of the pressure plate and disc plate from a 12" to a more standard size? That would also come with a throw out bearing that would fit the pressure plate.
This post was edited by PapaBear24 on 10/19/2023 at 01:08 pm.
C5022K
9G03B
C255234
