Rear mount side discharge finish mower?
I don't want a rear discharge because I have a 72 inch woods side discharge and I like the way it makes my yard look. When I'm done there are no visible grass clippings. If there are a few left in a wind row, I can easily pick them up with a leaf rake, put them in the garden or on a compost pile.
Does anyone have a used side discharge finish mower. No listing on YT's classified that I can find.
Thanks,
I just found Bane-Welker too.
That is where I bought my Kubota in 2019.
A+ dealer.
Best Land Pride, Next Taylor-Way, next Woods I have a like new Taylor way, come get it take it and try it any time you want.
It's been awhile, but I believe Woods will go either way,you just take the ends off for right,left or leave them on for rear discharge.
I have a kubota it works good and use on 50 hp tractor and do roadsides but slower then I figured it would be to cut good.
jm
It should fit in my 4x8 ft pickup. I may have to remove some parts.
If I make the trip to Tennessee, I will buy it.
I'm thinking of putting a mower on the Jubilee for my Boss in case The Farmall has a problem.
No rush, I will be in touch.
Better off with a 60 than 72 for the power the Jubilee puts out. Go with a rear discharge eliminates windrows if the grass is heavy. I have been using my Landpride 72 for 22 years now behind various sized tractors.
Vito
My Brush Hog finish mower is over 30 years old and still mows great. It has had a set of blades and a set of belts. I mow with a Massey Fergusson 50, just the perfect size. Not as fast as those fancy zero turns but it leaves a great looking job even in rough areas because it rides on the four casters and has a roller in the front middle.
