casual jon
New User
i have a 966 international tractor with a 565 koyker loader on it when i curl the bucket in it will uncurl fairly quickly , was told to let it un curl all the way fairly close to ground with tractor off un hook the return line on one cylinder start tractor back up and curl bucket back in and see if it leaks at cyl or the hose is leaking if oil pours from cyl then its bypassing on inside if hose pours it will be oppisite side. ican find no leaks external, which hose is the return hose on the cyl. i am not very mechanical either. Lol
thanks for any advice you have.
