Brillion seeder
I have a Brillion SP10 seeder than I really like but have an issue with sides feeding differently and more importantly holes feeding differently.
Manual says you can adjust feeding but bolts/screws are very rusty?
Please advise.
Spray the bolts with your favorite penitrant and start working with them. I've had 3 grain drills in my life and all seeded different from side to side. I never felt it made much difference as long as you are getting the desired pounds per acre across the field.
set 1 side use a tape measure and match it.
another thing i learned open both sides too far then close to desired setting. if there is freedom in levers and you start seeding they can open more after desired setting
Spend a week spraying the bolts with 50/50 ATF and acetone. Stuff is amazing and CHEAP. I use a pump oil can to apply.
My seeder also isn't pin point accurate. But for hay fields and pastures I run half amount and seed North to South and then East to West. Also eliminates the rowed look . I know not a solution to your problem, but does make an even stand.
