Maverick 600 Front End Loader
Possman
New User
Does anyone know who made the Maverick Front End Loaders? Or where to get parts/specs? I am trying to find some parts/information about a Maverick 600 Front End Loader that is on my 1956 Massey-Harris MH 50 tractor.
What kind of parts? Hydralics are most likely common off the shelf seals and O rings. Other metal items are easily made or replaced with common steel or hardware store stuff.
If you have done some web searching for Maverick loaders and don't find anything, it is not surprising. Many companies that built loaders during that time frame are long gone, either closed down or bought out by another. The reality is a parts book is not going to do much for you, if you can't find a dealer for them.
We don't know your mechanical background (hydraulic related in this case) but you will need to be able to identify things properly to find parts. If you ask for assistance here to ID something posting pictures will help.
To post pictures look down the page a bit from the box where you type a reply, and you will see a bar that says ''Upload Phots/Videos''. Below that is a button that says ''Choose Files''. Click on that button to go to your device where you can search your files to find the picture you want post, select your picture, then click the ''Open'' button and the program will upload that picture to your post. There is a size limit of about 7 MB of pictures/video per post (not per thread). That can be one picture or the total of several pictures in a post. This is the same in Modern and Classic views.
As DeltaRed posted for things like hydraulic cylinder sealing parts you will be working with local hydraulic shops or places like Baum Hydraulics. For valves and pumps hydraulic shops, Surplus Center, and Summit Hydraulics are some of the go to places for replacement ones. For hard parts, like pins and frame members you will need a fab shop to duplicate the old ones, if you can't fab them yourself.
eBay is probably the most likely place a manual or some other literature may turn up. You could post a wanted ad in the classified section you will find on the YT homepage.
YT Classified Ads
