Every thing was working fine. Did some hay fields and came home and shut it off, no overheating nor any kind of problem. Fired it up the next day and the AC pump went nuts inside....
Got all the replacement parts including a purge cannister and a gallon of purge solution. The compressor and dryer plus seals will be the new parts.
I know that you need to flush from the high pressure port tubing from the compressor to the condenser coil, leaving the dryer port open to allow the discharge and then from the dryer outport tube up through the evaporator and out the return spiggot on the compressor...for the discharge.
Other than anything you care to offer in the way of help, do you worry about getting all the purge solution out or will the compressed air final process take care of that.
As usual, thanks for your time and thoughts.
Mark
Mark
