jd2cyl1943
- Location
- Bemidji, MN
The other wheel is off!
Yes, they may look unstable but it actually is very stable and supported the tractor while it was off balance due to a wheel missing.
This is the home-built puller we used to get the hub clamp off. We put a 20 ton jack against the end of the axle and used it to pull the clamp off.
Another pic off the puller.
How much the steel plate bent under the force of the jack before the clamp came off. we were starting to get concerned over the bend when it popped of.
The wheel.
Both wheels leaning against our shed.
Evidence there is a seal to replace.
The wheel.
