Ok I have an Allis Chalmers 190 gas that recently had the fuel pump go out so I put a universal electric fuel pump on it been running fine baled several acres of hay over the past two months. Now it started sputtering like it was running out of gas then it would clear up for a few minutes then sputter again now it will barely start and die,so I checked the fuel filter and made sure there's plenty of fuel at the carb. I took the carb apart and cleaned it . I tried it again and it wouldn't do the same thing. I even tried spraying starting fluid in while it was trying to run and it didn't make a difference. So now I changed the distributor cap and rotor cap. Didn't make a difference. It's getting fuel what's the problem?
