WI Dan
- Location
- Northern Wisconsin, Price County
I have to stack my bales outside, under a tarp. I want to elevate them off the ground. Someone suggested pallets, but I don't want to deal with old rotten pallets and nails...
I have a million small poplar (aspen) trees to cut and clear. Ranging from 1" diameter to 8" diameter. I'm thinking of using those as poles. Lay down the large diam ones, 2-3 feet apart. Then lay smaller diameter trees perpendicular across, spacing 6-10" apart.
The bales are big: 1,100lbs or so. I'd like to stack 2-3 high.
The ground is heavy clay, slightly sloped.
Do you think this will work?
