Tufline disc
Have an older Tufline wheel disc that does a great job but would like rear gangs to cut a little deeper vs. front. Spring on front
has nut on top and bottom of spring--how do I adjust?
Most tandem discs cut more in the front than in the rear, That was the way they were designed. But to get more action on the rear you may raise the hitch or being unfamiliar with that make of disc, I think you should tighten the rod and sring
