Ford 2000 gas 3 cyl
waynerees
New User
Was running fine got hot and went to missing, spark advance tube was broken fixed it. New plugs, new wires, cap, rotor, points now missing on 2 cyl no valves stuck. What am I missing?
Swap the spark plug from 1 or 3 into number 2. See if
the misfire follows the plug meaning there is
something wrong with that spark plug. Also need to
make sure the new wire is providing spark to number 2
plug. If no problem found you need to check the
compression of the cylinders.
