Any of You John Deere Garden Tractor Guru fellas know how to help Me . There are 20 times the fellas hanging out here than at Garden tractors . If any of You can lend a hand ...I need the John Deere part Number for a coil pack on a LS 172,,, 14 hp . Kawasaki engine. No spark ,. engine will crank , Thanks Guys in advance
Re : Your post..
Their is NO LS 172, Their is a LX 172 listed with the coil information for the 14hp Kawasaki engine.
You can view LX172 at the following web site :
https://partscatalog.deere.com/jdrc/navigation/equipment/61487
Select the following sub sections
15 Engine
6 Flywheel
7 Their are 2 listed for the 172 ???
This post was edited by Jo Bird on 07/13/2023 at 08:16 pm.
If it is set up like a John Deere unit that I have the coil is plugged into a relay usually closed to the bottom of the engine. This relay controls the coil
function for safety purposes. Make sure your safety switches are working properly. Just a thought.
The first thing I would do is remove all rust
from the flywheel.
Second thing: I would set the gap between
flywheel and ignition module by using 3 dollar
bills which is close to 0.10 inches.
Third thing; remove the kill wire.
fourth thing; inspect the spark plug wire and new
spark plug.
Fifth thing; order a new ignition module.
I had the same problem with one I used to have. Bought a new ignition module. Problem solved. The module at that time was a lot cheaper online. Good luck.
Just an extra note on the 14hp Kawasaki engine that I have. The lead wire that is usually the kill wire on most all magneto coil engines. This Lead has to be
connected to run. I too ordered a new coil just to find out with this lead disconnected engine won't run.
Most of those old single cylinder Kawasaki engines had a 'trigger' module on the right side of the engine. its about 3/4 square and has a
mount tab on it and one wire going to it. In all the years I worked on those, I never put a coil on one, but I did change several trigger
modules when there was a no spark issue.
