Old style removeable valve stem
Eldon (WA)
I have some old rear tractor tires that have a female threaded sleeve on the removeable part of the valve stem. Does anyone know what these were called, I'd like to see if I could find some new ones but haven't had any luck.
Yes they are available. Just specify which one u want
when u go to the tire shop. They are the old style ones.
(quoted from post at 11:46:33 07/13/23) Yes they are available. Just specify which one u want
I've tried that, just got a dumb look...was hoping for a part number I could look up on the internet.
Lucky for me, I had a few in a drawer. I went to drain the chloride out of the tires on that 600. One had the stem that went inside, which seems to be common, the other one went over the outside. That one crumbled. Probably why they don't use them anymore. I had a whole handful of the internal ones, but I only saw one of the external ones in there. Lucky me.
then i know why u got that look, the stems are older than the parts man. but dont matter as they should have both in stock anyhow.
(quoted from post at 16:22:45 07/13/23) then i know why u got that look, the stems are older than the parts man. but dont matter as they should have both in stock anyhow.
Stopped by a major chain and showed them this pic and they brought me the newer style...I showed them the pic again and he said no one uses them anymore...I told him I was someone! The other gal there said I had a point LOL! I thanked them and said I would be ordering online...
Well if you have old tubes in an old tractor its not ur
fault. Its the way they were back then. They should at
least have a few in stock , BUT if it was not a tire dealer
then yes ur out of luck. Nobody will stock them.
