The hydraulic remote cable on my Allis 7040 broke in the cab.I was able to find the part and installed the new cable.It seemed as though I had installed it correctly but when I attach a implement ,I am unable to get the hydraulics to lift. The cable behind the tractor is attached to a plate on a rod. I am unable to move this plate manually. I there a way I can physically check to see if I have bigger problems than a remote cable? I only have 1 set of remotes as the other cable broke years ago and I had no need to replace it at the time.All told I have spent 6 hrs on this problem and have accomplished nothing.Any help would definately be appreciated.Thanks Dan
