Alternator update
super99
I put the battery tester on the alternator and it showed 14. I took the cover off of the regulator and when I pushed on the bar it charged 14 until I let go of it so Ill try replacing the regulator first
(quoted from post at 17:59:47 06/17/23) I put the battery tester on the alternator and it showed 14. I took the cover off of the regulator and when I pushed on the bar it charged 14 until I let go of it so Ill try replacing the regulator first
ight only need to burnish/clean contacts
super99,
If the contacts were closed, then the need to be cleaned. Better yet, replace the regulator.
By the way, alternator output voltage is just that. Some are marked no voltage.
What's important, and the proper way to check voltage, is at the battery terminals,
Guido.
