(quoted from post at 00:33:34 06/12/23) Hobo, is the info in his post 100 percent perfectly
clear? No, but the percentage of post on forums like
this that are perfectly clear is very low. The main part I
feel that should have been added but was not that the
engine is running on propane. If everyone had a steel
trap memory and could remember what everyone on
here had posted simply referring to this post as an
update to a previous post all would be fine. The
problem is ..steel trap.. memories especially in older
folks are few and far between, so I give you the link to
the previous post. I am no propane expert but I have
worked on a FEW. This being a dual fuel engine the
propane is sort of an ..add on.. It sounds like the
propane system relies on sensing air flow being drawn
into the engine to initiate mixing in the propane fuel.
Since the propane system is upstream of the TBI
..Throttle Body Injector.. the fact that the ..grommet..
for the wiring to the fuel injectors of the TBI was
missing the air flow valve in the propane unit could not
sense the flow properly.
Previous post
