This is on a garden tractor tube. The valve stem wasn't in the correct position on the tube to match the hole in the rim. The tube was leaking around the base of the valve stem. I thought I'd fix it by putting a patch over the old valve stem hole and put on a new valve stem that would line up better with the hole in the rim. I ordered a couple and got a nice big patch over the old valve stem hole. The replacement valve stem showed up and I ran into an issue. I assumed the new valve stem would be just like a regular tire patch - only with a valve stem in the middle. I thought it would have the peel off cover that adher to the buffed spot on the tube after the vulcanizing fluid dried. Instead it is a plain rubber patch without the poly cover. How do you make one of those stick?
https://www.ebay.com/itm/133883439171
