Putting a woods L59 belly mower on a farmall BN
ClayS
New User
I bought a woods L59 belly mower from a guy that used it on his farmall A. I want to put it on my farmall BN. So I need to either find mounting brackets and a tensioner bracket or fabricate it all myself. My problem is I can't find any good picture or information on the brackets. Can anyone out there help me out?
I got one on Farmall A. big problem is making extension for the assembly that goes between the axle housings and has the pulleys on it. The lift handle might be the same and just bolt on.
Last I knew, you could go onto the Woods website, dig through until you find the correct manual for your application, and they had
pretty good pictures.
I bought a B with a woods mower. I'm not
going to use it . I could ship the
brackets.
Dude that would be awesome. What do you want for them? If you happen to be located in Michigan I can probably drive out and pick them up too.
Woods mower brackets for a Farmall B won't work on a BN - the B axle is longer than a BN axle, and that will mess up the mounting bracket alignment with the mower. Woods made a U (Universal) mounting bracket - for L59U and L306U mowers - that will work on both a B and BN.
No idea if these are universal brackets or not. Might be rigged up home made for all I know. I'm in Alabama. Can ship, might be expensive. Call if interested. 256- four 0 four- 0123
