Hello, i have a following problem with my ford 4000. The 3pt hitch is lacking power sometimes. Sometimes it has enough strenght even to lift the nose up, and sometimes it only slighty makes the nose lighter. Same time when the 3pt is lacking its lifting power the remote hydraulics stop working correctly. I have hydraulic push bar and it moves only little bit when 3pt stops lifting.
Has the hydraulic pump gone bad or some valve clinging or leaking?
My hydraulic pump is in rear.
