(quoted from post at 17:28:37 05/26/23) Hello 9 lives welcome to YT! I can help you out with the
pedal behind the brakes, that is the differential lock.
Your tractor PTO has a 2 stage clutch. Which means
the upper part of pedal movement releases the
machine drive clutch for the transmission gears. The
lower part of the stroke will disengage the PTO. So this
gives the tractor a ..live.. PTO. So when the PTO is
engaged and you are moving in gear you can push the
clutch down part way to stop tractor motion but the
PTO will continue to be driven. I am attaching a link to
another recent post I had remembered where a link
was posted to an Operating Manual for a 135, on page
23 of the manual or 32 of the reader this is explained.
The reader of the sight the manual is hosted on is a
little clunky but works. You can also choose to
download the manual.
Previous YT post
