jd2cyl1943
- Location
- Bemidji, MN
I'm trying to get the Hubs off my JD B. I stole somebody's idea that I saw on the JD discussion forum but I ether maxed out the 4-Ton jack or broke it. Any Ideas?
(quoted from post at 10:13:02 05/24/23) I posted this on the JD forum recently. Very similar to ztw2009's set up. I used 5/8 threaded rod and the hub wedge clamp. The big steel bar I used against the axle was off the press. Threaded rod you can get fairly reasonable at a hardware store. If you don't have access to such a bar you could get some steel flat bar and cut it up into smaller pieces and stack them against the axle.
Stupid picture didn't show up I'll try later
This post was edited by 620 John on 05/24/2023 at 08:14 am.
