I have a problem and need help/options. I have a CIH 4240 open station
diesel. My saddle tank has a pin hole, maybe 1/16. I was having issues
with rust inside the tank. I replaced the filters a couple times and
used a magnet to try and clean out the inside. I removed the tank and
the paint where I saw the leaking. The metal on the outside under the
paint was clean( no rust, looked like a drill hole). I thought about JB
Weld but figured I'd ask for some advise from some of you with past
experience? What ever is recommended to fix the leak would be great.
Would you think I may need to line the tank also? I looked into a new
tank, $1400 and not available. Thank You Jeff
