1973 JD 2030. Have had it for 15+ years, runs great. Pulled oil pan off to replace a leaking gasket and discovered a balancing shaft bushing in the bottom of the pan. Comes from the left shaft, middle bushing. Since this is the first time in 15 years that the pan has been off, I have no idea how long the bushing has been off the shaft! Yesterday? 20 years? First, can I replace this bushing without pulling the engine? Should I replace all bushings at the same time? If I need to pull the engine can I get by not replacing the bushing? If it were one of the end bushings I think it would be different but... Just looking for some opinions. Thanks
