Traditional Farmer
- Location
- Virginia
Looking at piping water from a spring gravity flow,need about 3/4 inch pipe.See this Vevor 3/4 inch flex tubing or pipe.Anyone used it? Priced pretty cheap is it any good?
(quoted from post at 16:41:48 04/23/23) Couldn't help but add my 2 cents on Pex.. Twice had house flooded due to mice/rats chewing holes in Pex. Be aware.
(quoted from post at 12:14:51 04/23/23) No the line will be run on top of the ground from a spring up on my mountain down to a road/trail probably 300 ft or so.Then I can park a water tank in the road and let it fill up.Worse problem I have are bears biting thru the pipe,so I'm looking for something cheap and easy to repair.really its for a couple friends for water for their gardens as I have water from another spring piped to my garden.
I would recommend trenching it underground, even if just a foot with a middle buster. Protection from bears, sun, trip hazard, etc. with not a lot of effort. PEX is great stuff generally, but the old poly pipe will work as well. Both are poly, just PEX is a cros-linked structure poly and stronger.
(quoted from post at 11:34:10 04/23/23) I'd like to but no way because of stationary rock on the surface and the terrain is very steep.The 300 ft I'm running the pipe is probably 75 to 100ft in elevation
