FAKEITORMAKEIT
New User
Hey yall , long time lurker, first time poster . I have learned so much from this incredible forum so thank yall.
As a back story i was given a 2001 century 2028 tractor . It was so badly abused and mistreated that the folks simply told me to come load it up. It only had 320 hours on it when i got it . But after being drove through a pond and flooded for Lord knows how long i finally went all through the little tractor and got all the seals on the rams changed . Went through and cleaned the motor inside and out , also had to physically scoop hand fulls of gunk out of the hydro reservoir it was horrible. But all in all i got it running like a champ and it has been a good strong tractor and having done all the work myself i learned alot! But one thing that i had to do that was not ideal was i deleted a tone of electrical that was what was once the wiring harness . So no lights , no fuel gauge no seat safety switch and no fuel shut off solenoid. And i rewired new glow plugs on its own new circuit with a toggle switch. It has a front end loader and has been running great . So i borrowed a small 4 foot tiller and when i worked it at the recommended 540 rpm and tilled up a 1/4 acre it started acting fuel starved . So i changed all the fuel filters and even installed a new lift pump and installed it closer to the fuel tanks like within 12 inches of the tank outlets . I drained the tsnks. And blew air back into the tanks and this thing still wont run . Sometimes for 5 minuted and longer if i open the fuel bleed screw. I have fuel gushing out of the bleed screw and the filters are full to the top with fuel. It was running fine before i used the tiller . I just can figure this out. I wonder if there is a electrical component thst is still doing its job partially? Any help would be great and i look forward to hearing from all of you! Ps i also loosened the fuel cap and completely removed it that affected nothing . Its so wild that this only happened after working the pto. It has been running fine with the FEL for a year .
