Mounting Hiniker 1300 on JD3020
kirby03476
New User
This message is a reply to an archived post by JIM MN on June 16, 2019 at 07:41:11.
The original subject was Re: Mounting Hiniker 1300 on JD3020.
I am wondering i fI could receive a copy of the mounting instructions.
If you don't get a reply, try emailing Hiniker directly. I mounted two 1300 cabs on Oliver and was able to get a copy of the mounting
instructions (free) from Hiniker. I was also able to get the parts pages for my particular models, which helped a lot as well.
(quoted from post at 18:33:22 03/26/23) Thank you. I will probably just do that or call them tomorrow.
That's probably your best bet. You replied to a thread from four years ago and nobody that uses classic view will ever see it. The ones who use Modern view only see your reply and have no idea what you are replying to.
It's generally not a good idea to respond to old threads with "me too" even if they ask the same question. Start your own thread.
Kirby, see your question. If you don't get the instructions you want, I have the paper information that came with the new 1300-Hiniker cab to be mounted on a 3020-4020 tractor. Includes parts list, mounting and wiring instructions. Would be glad to share with you..
(reply to post at 13:29:03 03/27/23)
Jim,
If you still have a copy of the cab mounting instructions, could I get a copy from you? I'm going to be mounting a cab on a JD 3020 and they would come in very handy.
Thank you.
