should be
should be in/out couplers on the back unless you have a western or standard that had a hydraulic delete option.
can you send pictures of the back of the tractor?
(quoted from post at 16:01:05 04/04/23) have a live line going to a loader control valve without using the rear remotes
Your 830 has a basic open center hydraulic system so it's going to be more complicated than just taking a plug out of a port and screwing in a hose. There is no place you can "tee in" without rendering the entire hydraulic system unusable.
With open center there can be only one main "loop" for the hydraulics. You have to find where you can put the loader valve "in line" in the system.
