1946 BN IHC
This isn't quite about tractors YET it still may apply;
How would one / except for disassembly/ remove old grease from ball joints, tie rod ends and the like.
The reason for the question; I would like to put new grease into all the joints on the front end of our RV this spring. Some of the grease has possibly hardened causing the steering to be stiff.
{my thoughts fit an oil gun with the proper zerk fitting and pump in::/ such as WD40 /until the old grease is nearly all removed}
Hopefully some of our more seasoned people have a better way.
Thank you.
Thank you.
