Prairie gold one paint
prairiecarr
New User
I am trying to find prairie gold 1 paint either in spray can or quart. Used to get spray cans from this site. They no longer have it. The tisco part numbers that was number one is now prairie gold two.
I have checked with a lot of MM suppliers to no avail. Any ideas?
Did you try Welters Farm Supply? There is a company that advertises in MM Corresponder and Prairie Gold Rush with MM 1 but I don't have that information at hand. Did you ask below in the MM section?
This looks like what you're looking for.
SMA Item code TP521 GAL
Did you try Stamms, they were the place to go to a couple years ago. They were hooked up with sherman williams. Qts, gallons, or spray cans.
Hello PC welcome to YT! I did a web search for ..tisco MM prairie gold #1.. it shows up offered by Agcrazy. If the price is what is fretting you, if you had not noticed everything requires more worthless dollars to buy it than it did a couple years ago. BTW, the Stamm Tractors mentioned is in KS.
Prairiecarr, I am also looking for Prairie gold one paint. I plan on painting a 1945 RTU that I think its supposed to be colored prairie gold one. Im just in the process of figuring out what paint to use and where to find it. Id like to use PPG paint because that is the paint Im familiar with. Keep us posted on what you find. Ive been looking around if I can find some Ill let you know. I have a post over on the Minneapolis Moline board that might be helpful for you to select the paint. Dale
In response to the suggestions to try Stamms, I talked with Kelly yesterday at MMCI winter show and they lost their supplier for paint, acrylic and polyurethane both. They have a new one but theyre in the process of getting the transition made with an expected time frame of a while DP
I guess I need to look at my stock,I have some MM paint but I have no idea what numbers,it is old,at least 20 years. I'll try to remember to look afternoon tomorrow.
