I'd like to replace a light switch with a switch/receptacle combo, such as this one - https://www.amazon.com/gp/product/B...M&linkId=cf2fc4fc8e281cbbc4e4b0d74cff5047.
I want to use the single circuit connected to the current switch. I've watched some YouTube videos about the process. It generally looks pretty straightforward. All the videos instruct to use a test light or the like to figure out which wire is hot and which is load. I don't own any such device.
Here's my question - if I connect the load wire and the hot wire backward on the first attempt, will it damage anything? Best I can reason, it would just result in no power to the receptacle. If that happens, I assume I would just shut the breaker off again and switch the hot and load to the correct terminals.
But I surely could be missing something.
Thanks!
Neil
This post was edited by npowell on 02/09/2023 at 07:23 pm.
Thanks!
Neil
