Ford 4600 w/ cab - 772 Loader work?
Ok Team. Have a Ford 4600 cab tractor - love this thing. Its our rake tractor and probably the favorite on the ranch - over the newer models. Would like to put a light duty loader on it. Need suggestions and guidance. Will a 772 loader work?
thanks
had a model 21 loader on my 4600 but forgot the loader brand name. Common brand, still made every day.
A 772 is a conventional loader in that the
frame goes back to the rear axle. It also
has the uprights where the rear of the lift
arms pivot.
I'm thinking there is no way you are going
to get one on on your tractor without
mostly destroying the cab.
Here is a 772 on a 4000 I used to have.
A 4000 and 4600 are identical tractors.
(quoted from post at 02:34:06 02/10/23) A 772 is a conventional loader in that the
arms pivot.
<img src=https://www.yesterdaystractors.com/cvphotos/cvphoto147152.jpg>
Yep, agree...no way. Thanks
(quoted from post at 23:27:25 02/09/23) had a model 21 loader on my 4600 but forgot the loader brand name. Common brand, still made every day.
Westendorf WL21 probably.
They're also quick-attach so you can drop the loader to make it handier to rake hay.
(quoted from post at 06:37:19 02/10/23)
Thanks. Looking at the pics and set up of those, believe it will work.
