White 120 radiator - oil cooler
HILLTOPHARV
New User
Seven weeks ago I removed the radiator for repair. I should have taken pictures then. I was able to get it back today. As I'm putting back together, things are going well, until I get to mounting the oil cooler on the front of the radiator. I have the 2 small, flat bars on the front of the radiator, but I forget how the cooler mounts onto them. I have 4 plastic coated U shapes...... but I can't figure it out???
Any help would be greatly appreciated!! Thank you, Tom
I can try and take a look at my 100s tomorrow when there is some light in the shed. Everything is packed in pretty tight for winter. If you could give me a phone number or email to send pictures to, that would work better for me.
Thank you for your reply. After posting yesterday afternoon, I spent almost 2 hours fiddling with those plastic coated clips until the answer popped up. The clips go horizontal and the open end slides over a tube loop. Then a bolt goes through the clip and bolts to the flat bracket that is behind it. It is surprising.... sometimes this grey hair wins!!
