flying belgian and cx100
jhwis
I think you have the cx100 like i do. Anyway, if you recall earlier this fall I had the master warning light coming on. I finally figured out the pto lever must work it's way forward just enough some times to trigger the warning. A quick push back on the lever and the problem is solved. Just thought I'd share in case you come across that. It was a simple fix, but not obvious at first. And I agree that it's a nice tractor.
