G John deere
KennyDiesel
New User
Its says to soak head gasket in engine oil before installing, is this correct.
I have block and frame removed , can I install block and head and then install frame, there is bolts going from frame to block?
No idea on the bolt up question, but the gasket label or manufacturers recommendation is better than the info from an antique manual that is likely using materials from that era. Go with the gasket info. Jim
