Pulled some more trees with my winch
DRussell
Took my 1030 Case and logging winch over to a neighbor and pulled some trees for him which were leaning towards buildings. His wife got a video of the last one coming down.
It was a good sized ash, about 3 feet in diameter but was fairly dead.
Initially he was going to cut it with the winch tight to direct the fall, but it came out by the roots.
Untitled URL Link
Why did it fall sideways? Were you pulling it in a steady pull or were you increasing the tension and stopping to see how it was reacting to the increased tension? What sized cable do you have? I have pulled on trees and heard the cable sing. Which is a wire in the cable breaking.
It was a steady pull once I saw that it was coming out by the roots. Winch cable is 3/4. When pulling out by the roots they often don't necessarily fall directly in the line of the pull. A bigger root on one side not breaking can direct the tree sideways a bit.
When I was a kid, my neighbor was killed using a dozer to take a tree down. Dozers didn't have any roll bars for protection.
Another man was killed using a chainsaw to cut a tree down.
IN both cases something went sideways.
Just be careful around trees.
Local towing company has a setup like that one a skidloader, setup a laid over payloader and brought it up out of a steep road ditch. Handy tool.
This is a tajfun winch I have on my Kubota 43 hp 4 wheel drive hydro with a tomahawk grapple on front.makes working with trees/logs alot easier
Rick, how much can you pull with this winch, logs only after they are cut or will it pull trees out by the root?
There was a fellow put a post on here some time ago about a big dead tree that was leaning the wrong way, he was wondering about felling it using wedges. I wonder how he made out?
Glad everything went safely. Those ash trees go where they want to go. I ve had a tree service remove about 25 of them and I ve removed another 20 or so. Not to mention the many that have blown over and need to be cleaned up. I was out today and saw some more that I ll have clear.
About 3 or 4 that I had removed (because they were too close to a building for me to chance it) did not fall where they had planned, but fortunately none hit buildings. The worst was a basketball hoop on a 4 inch steel pole that got crushed. Another came about 3 feet from the deck.
