caterpillar guy
On a 574 with the D-239 engine it has the Bosh pump P VAA /100H1100 2 more numbers I can't read. I'm looking for either a rebuilt or repair on it if possible. Leaks around the throttle or kill shaft when setting. Other numbers on it are 2220293 and O 460 304 and a couple more I can't read. I took pictures but the glare makes it hard to read and dirt I can't get off with things in the way to read the rest of the top part. Tried a rag and screw driver. This pump probably has about 10,000 hours on it. The tach quit working at 7500 plus ten years or so ago. Having trouble with starting also. Once started runs fine though on occasion it will have a stumble or bit of a surge/race to it. This makes me think the pump needs some work or a new or reman pump.
