Looking for advice here.
I am working on a 62-63 (I think) Case 430. Diesel,Triple range, with Eagle hitch and case power steering. No serial number tag so year is a guess based on research I have done.
It has a brand new throw out bearing, pressure plate and ceramic clutch disc. Tractor slips in higher gears on flat ground with no load. I am trying to figure out how to check/adjust the hand clutch. I can see it cam over with the range cover removed, but it feels like it slips.
Does anyone know the spec and procedure to check/adjust the hand clutch?
