Checking oils on cub 184 loboy
Ihnut1234
New User
Hi. I am working on a cub 184 lo-boy and I was wondering if anyone knows were to check the transmission oil, the differential oil, and the hydraulic oil. Thanks for any advice! -Henry
Any chance you see a plug in the side of the squareish part of the front of the transmission case? See link. BTW, from the page in the link you can view all the parts break downs for your tractor. On a PC it is fairly easy you just click the ..Cub gas tractor.. next to the Home on the upper left. If you are viewing on a phone you have to turn it sideways to see everything to get back to the tab links on top to show all the sections.
CNHI Cub 184 parts diagrams
While you are at it you might check the oil level in the final drives also.
Plug for each rear wheel.
