Company Logo (800) 853-2651 Shop Now
Tractor Talk Discussion Forum
How to bleed loader on Massey Ferguson 202
Dekester
09-22-2022 20:34:48
Bought this 202 and replaced 2 hoses on lift. Replaced most of the fluid and can't get the rest of it in. Figured the lines needed to be bled. Need advice on how to do that.
Also on same tractor where do you add power steering fluid? Only in canister? There is a cap that had OIL embossed on it just in front of the power steering pump. Thought that
might be for oil in the engine as I cannot find another place to add to engine. Thanking y'all for your advice in advance.
Dekester
09-30-2022 19:26:07
 Re: How to bleed loader on Massey Ferguson 202 in reply to Dekester, 09-22-2022 20:34:48
[quote="CVPost-miangus"](reply to post at 08:26:31 09/23/22) [Y
You said in a reply to above subject, "yes, that is the correct way to add oil into loader" I'm in the house right now, but know where the breather is, but I can't recall seeing the plug on the side that you said to use to fill it.
Thanks
Dekester
09-26-2022 10:29:18
Thanks for all the comments. They were appreciated and definitely helped.
Dekester
Usedtobeiowadave
09-23-2022 06:11:18
Mine has the engine oil fill close to the PS cannister and says oil on it. I just add PS fluid to the cannister after removing the top cover. There's a filter in there for the PS fluid you might check the condition of. Pays to take care of that PS pump, there's no repair kit for it and the replacement is about $500. Old's advice on the hydraulics is good.
caterpillar guy
09-23-2022 04:19:19
Like Old said.
used red MN
09-22-2022 21:54:09
On the power steering you do not say if it is a gas or diesel. The attached link is to the online parts diagrams for your tractor. Sections 162 - 170 cover the PS pumps, once you view one you have to click ..Table of Contents.. at the top to return to the section list. Basically a gas has a lid on the top that bolts down by a center bolt also a filter in there. The diesel just has a small plug on the top of the reservoir.
miangus
09-23-2022 08:26:31
 Re: How to bleed loader on Massey Ferguson 202 in reply to used red MN, 09-22-2022 21:54:09
Correct answer. You are filling the loader oil in the correct spot. The little breather on top screws out on mine, fill to the plug on the side. Removing the plug on the lower support will make a mess. It should bleed out just running it.
old
09-22-2022 21:07:32
Very simple cycle all cylinders and as you do check and double check fluid levels
Geo-TH,In
09-23-2022 02:51:36
 Re: How to bleed loader on Massey Ferguson 202 in reply to old, 09-22-2022 21:07:32
X2
I never bleed a cylinder.
Today's Featured Article - Pop's Tractor of Gold - by Gary Teate. My father was a simple man but could repair just about anythin mechanical that was ever made. From the time I was a young boy growing up in Jacksonville, Florida, I would spend a considerable amount of time helping my father repair or rebuild equipment and engines, etc. on our 2 1/2 acre "spread". Pop always dreamed of having more acreage out in the country where he could retire and tinker as much as he wanted and often reminisced about his boyhood days on his grandfathers farm in Montecello, ... [Read Article]
Latest Ad: Looking for a skid for a W_power unit----also a green & yellow John Deere antifreeze gallon can. [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
