Seemed like a good idea at the time
rockyridgefarm
I bought this trailer about 4 years ago and installed my previous seed cleaner on it. When it was built, someone said -Boys, I have a genius idea! Let s cover the whole thing with bedliner paint! Everywhere the paint stuck, the metal looks new under. Everywhere the paint got damaged looks terrible. I think I will be in a pretty bad mood by the time I get this all peeled off.
I picked up the new deck boards last week and am letting them dry out for a few months so they can shrink before installation.
My 11 year old implement trailer had 2 bad boards.
I was told I can't buy CCA 2x6 boards.
No one told Menards they can't sell CCA boards..
I needed an 18 ft board. Menards only sell 8 ft 2x6 and 12 ft
2x6. No 10 ft boards. Total cost was about $35 with sales taxes
for one 8 ft and one 12 ft board.
I'm happy I could buy CCA boards.
They were special order. It took a few weeks to get them..
We Rhinoline a lot of wear surfaces and some wear parts. The Rhino will trap water and rot out the surface behind it. We're still doing it, but I don't think we're gaining anything. The people applying it don't follow directions, which is where the problem begins. The maintenance crew doesn't send it for repair before the problem becomes major. It adds a lot of weight, for example, to a trailer. Reduces payload and when it comes loose, it comes off in chunks and ends up somewhere it shouldn't. If the applicators did their job correctly, we'd have a lot more rot. As it is now, the Rhino fails before the surface behind it. In our case, the problem has kind of taken care of itself. In your situation, you're probably dealing with improper application and you have to deal with the damage without a cheap/easy way to clean the iron.
Menards in platteville wi had 18 foot 2x8 treated critical structural on hand. Cost me $300 for 11 of them. They had enough to do 10 trailers.
A guy down the road had bed liner sprayed all over his Dodge pu. I think the
bedliner is the only thing holding the body on the truck. At least the flat
black doesn't show the rust as bad.
he decking should be placed with the sapwood up---that is where the greatest preservative retention is---and the boards will usually cup to shed water
My father bought an 89 F250 which he had Zbarted, which was a tar like undercoating. It trapped the
salt water underneath and promoted the rust. Bad idea.
It very similar to powder coat. Anywhere you scratch it the moisture gets in and the rust gets a start. The coating protects the moisture and the rust and instead of drying out and rust stopping until the next time it gets wet as is the case with paint, The bed liner and the powder coat maintain a perfect environment for the rust to work 24-7. The key is good prep including primer, before application.
