fastfarmall
Just changed oil in my new to me car, it run 203 at 65 MPH, with Mobil 1 Synthetic, put in GM 10W-30 conventional oil, and it runs 217 degrees at 65, is that normal, must be that much less friction, or what?
X2(quoted from post at 18:20:06 09/16/22) To expand on what Used Red said there are a lot of variables that go into what temperatures a vehicle runs at. When we do dyno testing in the lab I've seen it take over an hour of running at 100% engine load for engine and hydraulic oil temperatures to stabilize and this is under very controlled laboratory conditions. When out driving on the road there's no way to control the many factors in play so there's really no way of drawing meaningful conclusions from the results. It it likely that the synthetic oil reduced some friction but probably not as much as your two temperature readings seem to suggest.
(quoted from post at 14:19:42 09/16/22) Just changed oil in my new to me car, it run 203 at 65 MPH, with Mobil 1 Synthetic, put in GM 10W-30 conventional oil, and it runs 217 degrees at 65, is that normal, must be that much less friction, or what?
(quoted from post at 15:20:06 09/16/22) To expand on what Used Red said there are a lot of variables that go into what temperatures a vehicle runs at. When we do dyno testing in the lab I've seen it take over an hour of running at 100% engine load for engine and hydraulic oil temperatures to stabilize and this is under very controlled laboratory conditions. When out driving on the road there's no way to control the many factors in play so there's really no way of drawing meaningful conclusions from the results. It it likely that the synthetic oil reduced some friction but probably not as much as your two temperature readings seem to suggest.
(quoted from post at 14:35:17 09/17/22) Well of course! You were closely following a dump truck that all but eliminated aerodynamic drag on your vehicle. Just keep on following dump trucks.
