Must be Monday
kcm.MN
Location
NW Minnesota
Puzzle: https://jigex.com/jB83b
How does one manage that on what appears to be flat ground. No mud so didn't get in a sink hole and no water to say a pond edge. I guess the tractor just wanted lay over pay.
(quoted from post at 04:10:31 09/12/22) How does one manage that on what appears to be flat ground. No mud so didn't get in a sink hole and no water to say a pond edge. I guess the tractor just wanted lay over pay.
That could be only how it came to rest after rolling five times.
I knew of a fellow turned his Long 510 tractor over in the middle of a flat hay field. He was watching behind him and didn't notice how close he was to a round bale. Right rear wheel walk up the bale and over it went. He bailed off safely.
Looks to me like he is on the back side of a pool dam. You have 2 choices mowing that......vertical or horizontal. I had the same situation with trees at the bottom of the berm which didn't allow vertical. So I used a riding lawn mower and sat on the uphill side of the seat to mow the 30* bank with ATV studded snow tires on front and rear of the mower. No problems, wet or dry.
How old was the operator ? Might of had something to do with it. I can still hear the old man hollering SLOW DOWN. ,The Old Scovy.
Barrel race(pushing barrel with front end) at a tractor show one time. JD tricycle with the rear axles sticking out past the tires. Barrel upended and got under the rear axle and almost flipped that tractor.
