Kubota BX2200 loader options
ed12345
Can you bolt on a LA340 / LA344 loader loader to a BX2200. I realize I'll have to add the hydraulic control valve. But can you bolt the new loader frame to the old BX2200 tractor. Is the frame width the same and will the bolt holes line up?
The BX frame has not changed since inception BUT when you look into the cost and mounting of the valve you will change your mind. The tractors ordered from the factory with loader valve were roughly $800.00 to do it from parts will cost you over twice that and a lot of labor.
