Neighbor said he had an oil spot on his driveway from his 2007 Chevrolet 1/2 ton pickup. Thought it might be either the rear brakes or from the oil seal on the rear axle. He got to looking and the oil was coming off of the outter U bolt holding the springs to the rear axle. After scratching around for awhile he noticed that there appears to be a tiny hole due to corrosion in the rear axle between the two U bolts. Has anyone ever heard of this?? The hole is halfway up on the axle. I told him to clean it up and patch it with some expoxy as long as the axle is not compromised. Would this tiny hole compromise the axle to the extent that is would need to be replaced?
