White 2-85 questions
Tlarson
New User
I recently bought a white 2-85 and the hydro temp light flashes all the time. Where is the actual sensor located and what would cause it flash as soon as I start the tractor
Also the tach spins wildly when I idle it up, is there and aftermarket one I can buy
When you say Hydro temp, hydraulic or Hydraul Shift? Tach sounds like the cable needs to be lubed.
I'm assuming you mean the hydraulic temp. light. My 2-105 does the same thing. I will be interested in the replies to your question as I would like to fix mine. I do know that the hydraulic temp. is not high on mine.
