Question for John T
old popper
I have a JD 720 D with a pony. I installed a battery disconnect so while at shows children cannot turn the switch on and fry the coils on the pony. Question...do I need to re-polarize the generator after each time I use the disconnect?
Good Morning Old Popper, good question You ask Question...do I need to re-polarize the generator after each time I use the disconnect?
I agree with the other fine gents NOOOOOO...........Disconnecting the battery would NOT cause the genny to loose or change its polarization. Hey when the VR's Cutout Relay opens when the tractor is shut down, if alls well, the genny isn't connected to the battery OR IT WOULD DRAIN IT !!!!!!!!
Have a good day now
John T
