Round bale wagon and bale spear done
Alan K
Got the hay trailer done and the bale spear to use on the MM M670 Super. Works a little quicker on long trips than one at a time
with the bale fork lol.
2 better than one. Some had a high lift 3pt spear that would load a wagon one high.
Wondered about that but I don't want to go bouncing around with one on the three point any more than I have to and having to hitch up under a bale.
Thank you. Been looking for a spear for a long time and couldnt find one. Did find an old wide bale fork for the main frame and an old spear, made the rest
Nice job! Before I got a front loader, I had two bale wagons like yours, but they held three bales on each wagon, plus the tongues were longer and I hauled one more on the spear. I could load both wagons without unhooking them from each other by backing up out in the open field - they would jackknife without any help from me and I could get to the back of each one to load them. I used two 30 foot railroad rails cut in two for the runners on the wagons. The bad part was unloading - I used a cable hooked to another tractor to drag them off of the wagons. They loaded faster than they unloaded, but it was still worth it for the one - mile haul. As you said - much better than one bale at a time!
I was planning on doing 3 on the trailer but I didn't have enough iron on hand to extend it farther so I went with 2. Was going to do one cross ways in the middle and one on each end. I only have about 10 bales to haul out of each water way so at least it isn't too bad.
