sellener777
New User
So after some help i got an idiot light working properly on my two battery 12 volt system on Oliver diesel.
My existing conundrum is my ammeter seems to indicate a pegged charge when operating at anything other than idle.
Voltage reads 14.5 ish while running with load.
Voltage read 12.7 resting
Voltage reads a bit less say 12.5 with lights on resting.
I havent ran the tractor more than like 20 minutes to see if ammeter reading ever comes back down to 0 after operating for several hours.
Ammeter is a -30 +30 type.
New ammeter operates as old one did.not the ammeter I dont think.
Any thoughts?
Tractor has two 12 volt batts each grounded to frame.
So should be 12 volt system with increased cca
Would that system charge more aggressively or something?
Any thoughts?
